FMU removal
  • Thread starter Thread starter RayBrian
  • Start date Start date May 7, 2004
RayBrian
20
  • May 7, 2004
FMU removal, how?
after doing my research on the forums I found out that I no longer need the vortech FMU as i have 30lb injectors, calibrated pro-m MAF, (and also a vortech adjustable FPR if that matters?)
all this on a 92 lx notch 5.0 with V1-S Trim and all bolt ons, stock h/c
so, I know nothing about this FMU, I just need to know what to disconnect and where to connect it...
the more info the better! or pics =)
Thanks again for any help/responses,
Brian
RydeOn
Licensed to Chill
6,273
orange county, CA
May 7, 2004
  • May 7, 2004
This is what you do. On the bottom of the FMU are two fuel lines. Follow them down to the area where your smog pump and alternator are. Using a special disconnect tool, disconnect the fuel lines that go to the FMU. Now reconnect those lines back together. After this you disconnect the vacuum line from the top of the FMU and plug it or bypass it.
speedytang
765
Marengo,Ohio,US
May 7, 2004
  • May 7, 2004
If you only have 30lb injectors I hope your not running more than 6psi or you will run out of fuel. The FPR will only give you a 1:1 ratio and that will not be enough additional fuel for anything over 6psi.
RydeOn
Licensed to Chill
6,273
orange county, CA
May 7, 2004
  • May 7, 2004
The 30s will run well into the 370-380 rwhp range. All he has to do is turn up the base pressure a little bit. And make sure to do it on a dyno.
blown93feature
151
living on edge like the motor
May 7, 2004
  • May 7, 2004
I beg to differ with you on the capabilities of 30"s,they are good enough for just about 600 fwh and so isn't the factory fuel rails for that matter so he shouldn't have an issue with up to around 10 psi.I would say he needs to make sure that he has enough pump to supply the injectors and bump his fpr up a little but outside of that he will be fine I would also tune on the dyno to try and get that optimum 12/1 to 13/1 to keep her safe on wot
RydeOn
Licensed to Chill
6,273
orange county, CA
May 7, 2004
  • May 7, 2004
I wasnt disagreeing in fact it makes me happy to hear I underestimated the 30's. I'd rather go for those cuse they are so much cheaper.
RayBrian
20
  • May 8, 2004
alright, well I got my FMU disconnected and out of there, now however i'm having idle problems, MAF?? it still might not be calibrated for my 30lb injectors, my remote optimizer is on the way to make sure and calibrate the MAF correctly, and be able to adjust lean/rich conditions. Is there something else i need to check that might be giving the idle probs? such as the BBK adjustable FPR?
Thanks,
Brian
P
PRO50SC
1,012
Olney, Maryland
May 8, 2004
  • May 8, 2004
I would leave the FMU on there. I have a Procharger w/ 9lb boost. 30# injectors. Had the car dyno tuned a couple weeks back. I asked my tuner about removing the FMU and he said to leave it on. The car has no drivability issues so i took his advice and left it on there. I believe he told me unless I was running either 36 or 42's (can't remeber which) to leave it on there. The engine needs the extra fuel/pressure to feed the blower.
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
1991 3g alternator not charging
  • BigShowJoe
  • May 12, 2024
3K
Fox 5.0 Mustang Tech Mar 30, 2025
Chuckster101
C
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
