Fog light help...
Ok, my fog lights worked when I first got my car, and they both just quit working. I didn't bother with it, because I was getting a new body kit with new fog lights. Well, when I got my Stalker kit, the foglights did the same thing. Worked for a little while, and both just quit. Again, I didn't mess with it. Well, I get the Roush kit on, and i want these freaking things to work. They are hooked up, fuse is fine. WTF is the problem!? Also If one headlight goes out, wouldnt it be the low and high beam, seeing as they work on one bulb, or can JUST the low beam go out? I have a driver side low beam out. Checked the low-beam fuses too, they're fine. But I need some help. Thanks Stangnetters! haha
First and foremost, check the bulbs (which you probably already did) and power supply to your fogs. If you have no power with the foglight switch turned on then we have a problem in the circuit somewhere, or in a switch itself. It is possible that the foglight switch may be defective, or when you turn your headlights/parking lights on, your foglights arent being told to switch on as well. Nothing any of us can really diagnose on here.
As for the high/lo beam, sure its possible. You likely have a problem in the headlight circuit somewhere. I'd have to assume if it was the switch, you would be having the problem with both sides.
I wonder if your 2 issues are related? Quite likely actually...
