Hello there, I'm getting ready to install factory fog lights in our 2000 V6. I've already installed the lights.Tomarrow I'm picking up a new switch from Ford.We have a factory wiring harness for the fog lights that we just recieved from CJ Pony Parts.
The wiring harness came with no instuc's. my question are.
theres a blue wire (close to where the harness plugs into the lights) that has the round connector like a ground. is this wire a ground? or does it go to something else inside the drivers side fender?
it has two plugs that resemble a cross. these plug into the head light harness somehow correct? or the fog light switch?
and my last question theres a yellow and green wires also at the same end of the harness.where do the go?
it just seems theres not enough wire to plug into the switch in the console and the headlight wiring also. Maybe after I get the switch it will make better sence to me.
does anyone have a left over install instuc's? I need some help here. :0) thanks for any help Jace
Nice stangs. I wish I had an 70's Mach and 03-04 mach...Sorry I can't help you out with your question.
