Fog Light Switch - Where do it go?!?!
TF Mondo
I've got a 66 convertible that I will be putting my new fog light kit on. My understanding is that the fog light switch goes in the approximate location of where the convertible top switch is. If thats the case, just where does the switch for the fog lights go?!?!
Fog Light switch
I had the smae issue last year, i did some searching on the net and basicly it goes on the underside of the dash (the lip) on the left of the steering column between the fresh air vent knob and the column. You will find a hole with a flat side, it goes there. It will match the size of the switch barrel. Push through from under the dash, secure with nut, hook up the connector to the harness and you are done under there.
