For people considering using POR-15
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
I am an advocate of the stuff. I have used it on my floor pans, differential, frame, and most recently, my gas tank. Im posting this just to show you what a difference it can make..
Before = rusty old gas tank
After = wire wheel'd off the loose rust and it came out looking great! (forgot to take a picture of the top side)
did you blast the rust off before applying the por15 a friend of mine seems to think that it acts as a rust inhibiter
It specifically states not to grind all the rust off, just to remove the loose rust with a wire wheel or wire brush. then i scuffed up the rest of the tank with a red scotch brite pad and painted away.
There is a paint store here that you can buy automotive paint from. Thats the only place locally i found it. i was told that sherwin williams carries it and a few other places, but i cant remember off the top of my head.
isn't that stuff expensive
I believe it was 28 bucks a quart. But i have painted my gas tank, floor boards, differential, and rear frame, and i just not got down to a 1/4 of a quart left. The stuff is self leveling, goes on thin, and they say to use up to 3 coats for maximum coverage.
would you recomend it on accesory brackets
The stuff i have isnt the high temp stuff, but i was told that they make a POR-15 engine paint... i would probably check into that for anything attached to the motor.
yea we sold this at the auto parts store i worked at its great stuff.. they make one for gastanks you can dump inside and wash it around to coat the inside of the tanks... people seemed to love that one just as much i have never heard anything bad about it:SNSign:
sis it work good with the floor borads? i have a monster puddle in my car from a un know leak and think i may use this stuff while i have most of the interior out...
where do you get it at?
