WOW! I have a ton of respect for Tim and his tuning p
rowess, but that recommendation is downright careless. Running a K&N without the oil is not wise unless you only run the car indoors.
U.M.
Well I have both foam filters and like 2 K&Ns....as well as a paper filter.
Paper will definatly > ALL when it comes to filtering....freegin nothing gets through that stuff. But the reason automanufactors do that is bacause they dont know where you live or where you drive your car. You could live in the desert for all they know...so they must provide a filter that filters dust VERY well.
K&N also offers their foam/oil wrap that goes around your K&N filter to help keep dirt out if you in a very dusty area. Their regular filters with oil definatly keep alot of dust out...but still some will make it through.
And then we come to regular unoiled foam type filters like I have. They are VERY dense and thick...but stopping dust, they will not. They will stop some, and will definatly stop the big stuff though. Many people use them without issue...and I have no problem running them on mine.
And finally unoiled K&Ns. Quite honestly, an unoiled K&N will do a perfect job at filtering bugs and anything remotely large. Dust...it wont stop much. But what the adverage cobra driver encounters is nothing....definatly wont harm the engine. What you want to keep out are rocks, road debris, leaves, bugs, large dust particles, ect.
I guess he feels that if you must use a K&N filter, then oil is a larger threat to it, then a little dust.
Im also sure he would ask where you live/ drive before recommending that...if you lived in the desert I would hope your smart enough to run a paper filter and forget K&N altogethor. And if you did use K&N in a dusty area, I would say to run oil even with a KB cobra....but frequent MAF cleanings would be a must
Be smart about it...I for one, let off the gas completely and push in the clutch if I happen to run into the middle of a dust cloud from construction or whatnot. If I happen to be on a dirt road following someone, I stay WAY back and stay at low RPMs very light throttle. Little stuff like that helps keeps dust intake to a minimum.
