I must have deleted the PM from the person who asked for pics of this, and unfortunately I don't remember the name, sorry.
Here are the pics of the hydraulic line bulkhead I made for my scattershield. As I described in another post, this will enable replacement of the exterior hydraulic line(s) in case of a breakage. The 2 internal lines (between the bulkhead and the hydraulic bearing) will unlikely need replaceing as they are protected inside the scattershield and held in a fixed position by the bulkhead. The 90* bulkhead connectors allow me to use straight ends on the side coming from the bearing (making it easier to install/remove) and 45* ends on the lines up to the master cylinder and bleeder. The 90* forward and 45* out gives enough throw to shoot through the biggest opening of the headers. I am making another bracket that will bolt to one of the existing scattershield bolts (empty holes in pics). That bracket will hold the hydraulic lines away from the headers as they head to the master cylinder and bleeder. I will post pics of those when it is completed (later this week)
Hope this helps you in your build
