Ford Alarm System
  • Thread starter Thread starter Mr. Potato Head
  • Start date Start date Jan 1, 2006
M
Mr. Potato Head
83
DFW
Jan 1, 2006
  • Jan 1, 2006
I bought a 91 LX 5.0. It has a 5 spd but was originally an auto. It also has the Ford Alarm which I want to take out since it looks, to say the least, non-factory.
What are the implications of simply ripping the thing out (not literally rip)? Are there connectors I need to reconnect to each other when I remove the alarm? It looks like a ECU with plugs. Where do I connect the plugs when I remove the box, etc, etc? Thanks.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jan 1, 2006
  • Jan 1, 2006
I didnt know that 91 mustangs had factory alarm systems. Anyone else have an opinion on this?
M
Mr. Potato Head
83
DFW
Jan 1, 2006
  • Jan 1, 2006
Like I say, I am pretty sure it was added in judging by the mess of wiring under the dash. I do have electric locks with a keyfob and I want to keep that setup. But I want to lose the alarm....
HISSIN50
34
129
Jan 1, 2006
  • Jan 1, 2006
Assuming aftermarket alarm:
If the starter kill was wired passively, like most are, as long as you leave the relay intact, the car should still start. Otherwise remove the relay and reconnect the cut starter interlock wires (should be terminals 30 and 87A on the relay).
For the locks, again, you can leave the relays and let power travel through the common and N.C. terminals. Otherwise you can reattach the wires as they were stock. There should have been two OEM wires that were cut. Most installers grab the lock wires at the top of the driver kick panel.
If you leave the relays intact, you are ready for another alarm down the road.
Of course, some installers do stuff differently, but what is mentioned above is pretty conventional.
Good luck.
M
Mr. Potato Head
83
DFW
Jan 1, 2006
  • Jan 1, 2006
I'll need the good luck.... I just successfully disabled my vehicle. I have no idea what I am doing. Tomorrow I will call around and see who will cut the box out and connect the appropriate wires. Damn. I have to tow it. Damn again.
The alarm is a factory Ford Vehicle Security System. Installed after production. I don't know when.
HISSIN50
34
129
Jan 1, 2006
  • Jan 1, 2006
Ah so. I dont know how the factory stuff is wired up (though some peeps in here do). FWIW, bypassing the starter kill should be very simple if you want to do it. All you need is two fingers.
Good luck.
M
Mr. Potato Head
83
DFW
Jan 1, 2006
  • Jan 1, 2006
Good luck.
What do I need to do?!?
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 2, 2006
  • Jan 2, 2006
i've taken out many alarms in my day as they are major pains in the ass and any time i did it i just reconnected any factory wires that may have been spliced into by alarm wiring.
M
Mr. Potato Head
83
DFW
Jan 2, 2006
  • Jan 2, 2006
I wish I could see this setup clearly enough to do that. It looks to me like wires come off the harness under the dash and plug into the alarm box. There are a few wires spliced into the system though but I don't think they will put it back together by themselves.
How do I start this thing so I can take it to the shop?
HISSIN50
34
129
Jan 2, 2006
#10
  • Jan 2, 2006
  • #10
If you put a test light on the little slide-on (S) terminal wire on the top of the starter solenoid and try to crank the motor over, you probably wont see 12 volts at that little wire's connection.
BEING SURE YOU HAVE THE CAR IN NEUTRAL, EMERGENCY BRAKE APPLIED, AND OTHER SAFETY PRECAUTIONS TAKEN, you can turn the ignition key to the 'on' position. Then remove the slide-on terminal on the solenoid and run a jump from the slide-on post to the battery lug on the solenoid (the battery lug has several cables attaching to it, and is often the firewall-side most terminal on the solenoid).
WHen you touch that little thin wire to the battery terminal, the car should turn over and start.
I am guessing that right now when you try to start the car, absolutely nothing happens. This indicates a starter kill (which the above procedure should circumvent). There might be other measures taken to keep the car from starting, but getting it to crank is the first step.
Good luck.
M
Mr. Potato Head
83
DFW
Jan 2, 2006
#11
  • Jan 2, 2006
  • #11
Well, that didn't work. What else should I try? I took some pics to maybe help you out with what I am seeing but they are too big. I can email them to you if you want....
HISSIN50
34
129
Jan 2, 2006
#12
  • Jan 2, 2006
  • #12
Does the car crank right now?
M
Mr. Potato Head
83
DFW
Jan 2, 2006
#13
  • Jan 2, 2006
  • #13
No. The fuel pump primes and the dash lights come on, etc but the car doesn't make any starting sounds. It's almost definitely a starter kill.
HISSIN50
34
129
Jan 2, 2006
#14
  • Jan 2, 2006
  • #14
If you do what I outlined in post 10, it will bypass the starter kill.
When that little top-post wire on the solenoid sees 12 volts, the starter solenoid energizes. When you remove that slide-on wire and touch it to the battery post on the solenoid, you are providing the 12 volts that otherwise are not making it to the solenoid via its natural path (because of the alarm).
Let me know what you think. Good luck.
M
Mr. Potato Head
83
DFW
Jan 2, 2006
#15
  • Jan 2, 2006
  • #15
What I think is that it sounds great! However, I tried it between post 10 and 11 and it didn't make any change. I am going to get some sleep now and I will eagerly anticipate your fresh ideas in the morning. Either that or call a tow truck!
HISSIN50
34
129
Jan 2, 2006
#16
  • Jan 2, 2006
  • #16
Here is Jrichker's master post on troubleshooting and circumventing the starter interlock circuit.
Number 3 on his nice list is another quick way to get the car to crank (this method will circumvent the solenoid as well). The car should crank with this method no matter what, unless the battery, battery cables, starter, starter cable, motor grounds, etc are at fault.
I know my posts are not very concise or easy to read, so perhaps Jrichker's post makes (a lot) more sense.
Good luck.
M
Mr. Potato Head
83
DFW
Jan 2, 2006
#17
  • Jan 2, 2006
  • #17
Thanks for the link! I can start it using the screwdriver method. Awesome, thanks again!
HISSIN50
34
129
Jan 2, 2006
#18
  • Jan 2, 2006
  • #18
If you cant start it using a jump from the thin stud to the battery lug, the solenoid is not energizing properly.
Glad you got it though.
powertrax91
598
New York
Jan 2, 2006
#19
  • Jan 2, 2006
  • #19
Mr. Potato Head
If you have a factory installed or dealer installed Ford alarm system it carries a LIFETIME warrantee. You will only need to pay for labor at your local ford dealer if you want to keep it...
M
Mr. Potato Head
83
DFW
Jan 2, 2006
#20
  • Jan 2, 2006
  • #20
Thanks for the info, but I want it OUT!!
  • dan50
  • Jul 18, 2026
dan50
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
