Ford Day will be on June 17th at Lebanon Valley Dragway. There will be 2 heads up classes one bracket class. Engines fire at 10:00am Here are the rules for the heads up classes.
2006 Factory Shootout
Aftermarket "Street" head, cams and intakes allowed
03 or newer Cobras and/or power adders not allowed
Ford/Mustang Minimum weight 3050 lbs
Aftermarket Heads(except iron GT-40/p) or 3V/4V add 150 lbs
Ford OEM Stock 5.0 HO heads deduct 150 lbs
16 inches manifold vacuum required
Mufflers required
26x8.5 slick or 28x10.5 DOT maximum measured
2006 Real Street Shootout
Inline valve Windsor or Twisted Wedge Street heads only
NMRA “Real Street” superchargers or single stage nozzle/plate nitrous only
single power adder only
96-04 SVT Cobra 4V allowed
Stock style suspension only, coil overs allowed
28-10.5 Slick or DOT maximum
Naturally Aspirated 302 block 2800 lbs minimum
Naturally Aspirated 351 block 3000 lbs minimum
Power Adder 4.6L or 302 block only 3200 lbs minimum
Street intercooler/aftercooler add 100lbs
4.6 2V deduct 100 lbs
Mufflers required
Mufflers required
Mufflers required
