Ford racing boss302 or Dart short block build up with...!
Stang302h.o
Hello, i just wanna ask an information about what pistons,crank shafts,heads,cam etc... will fit on the short dart302 or fordracing boss302 block?good compression with kennebell 2.1L bolwzilla/flowzilla,with a good torque.....part numbers could be,
Thanks,and appreciate for the help
Is this a street car? A Kenne Bell 2.1L probably won't make enough power on pump gas to warrant either one of those blocks unless you plan on stroking it and adding some aggresive parts to the mix with a little squeeze (nitrous), or water/methanol injection for added flavour. Put a set of decent rods and pistons in your existing 302W block and call it a day. :shrug:
