Ford Racing Driveshaft
Scott7512
153
Branchland WV
I just had my 93 LX on the highway yesterday and around 75 there is a slight vibration present. I could not tell where it is coming from. The car is hardly ever on the highway. Mostly a beer getter. It has an aluminum ford racing driveshaft and 3.55 gears. Should I change the mounting holes for the shaft at the rear end. I know that when you take off a shaft you should mark it and put it back the same way. Since it was a new shaft I did not put any marks on the rear end. Should I try rotating it?
The shaft has a green or yellow paint mark and there should be a crayon line on the companion flange, they should line up and be in balance, if that doesn't work then try rotating as the guys said above.
Reactions: jrichker
Tire pressure is at 30 psi cold on all. The car is normally only driven a couple times a week for short 10 mile trips. The other day I took it on a longer trip. I drove about 45 miles before getting on the highway. I am going to try rotating the shaft and also check the rear pinion angle because the car was lowered when I got it and I have since raised it back up slightly. If I don't find anything I am just going to live with it because it is very slight.
6 months or less...nothing. Longer than that I take them off.
I've never really had an issue with flat spotting. I usually inflate the tires to max pressure and when we get a warm day in the winter I might pull it out of garage to listen to it idle
Sent from my iPhone using Tapatalk
Reactions: Shakerhood
Car lowered? Either way what about drive line angles? I have the same drive shaft and I have a slight vibration too. Stock user control arms and the car is lower than stock. I know if you cause the drive shaft to bind it can vibrate.
Gear bangers right put on stands. I had an 82 gt years back, that I didn't mark front yoke, when I put new u joint on. I had a vibration above 60mph. I put on a new joint, rotated front yoke, went away. If you suspect tires rotate tires, shake or vibration will move to front. You can also find a driveshaft shop that can check and balance if necessary. Theirs a technique, I've never tried it to balance shaft, by installing a hose clamp. Try the other methods first.
