Ford Racing FR500 DOHC High Lift Camshaft Kit - '96-'04 $1100
na svt
21
No longer available from Ford.
Ford Racing FR500 DOHC High Lift Camshaft Kit - '96-'04.
Aftermarket cams from Comp Cams run $1200, springs $399, valve seals $100 retainers $100 and you would still need to spend another $200 on followers and at least $500 on valves to match what's available in this kit. That's $2,500!
Product Details
High Lift Camshaft kit developed by Ford Racing. Works in naturally aspirated and supercharged applications. For use on all DOHC 4V cylinder heads. Camshaft have great idle with excellent power through 7,000 RPM.
Kit comes with:
- 4 camshafts
- high lift valve springs
- valve seals
- 32 cam followers
-v4 cam bolts
- ferrera stainless intake and exhaust valves
camshaft specs
Intake: 258 deg. @ .003 w/ .472 lift
Exhaust: 254 deg. @ .003 w/ .472 lift
Centerline: 109 (intake and exhaust)
The cams are capable of making over 400rwhp in a 281 ci engine and over 400rwhp with more cubic inches, 302 or 324. I've seen as much as 450rwhp in a 10 to 1 compression engine.
There are only four kits available as Ford has stopped production on these.
nasvt at hotmail
