  • SN95 4.6L Mustang Tech
Ford Racing Oil Filter?
  • Thread starter Thread starter [Twitch]
  • Start date Start date Mar 29, 2006
First Prev 2 of 2
RandyStinchcomb
1,159
Randallstown, Md
Mar 30, 2006
#21
  • Mar 30, 2006
  • #21
Frpp oil filter is total over-kill, the standard Motorcraft FL-820-S (which are made by Purolator btw) is/are plenty fine for performance appts. btw what what said about Fram filters is true, eversince they were bought-out @15 years ago, ther quality went downhill.
laxdman20
95
Va.
Mar 30, 2006
#22
  • Mar 30, 2006
  • #22
Fram sucks. Lowest quality oil filter I have ever come across.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 30, 2006
#23
  • Mar 30, 2006
  • #23
Stang|ess said:
Don't use Fram stang2003gt, they're crappy.
if you use this frpp oil filter, can you use if for more than 1 oil change?
NEVER reuse a filter. even extended oil change companies such as amsoil recomend the filter be chnaged every 5k miles max. and thats when using very high qualiy synth.
your better off swaping the filter every 3k and just toping off the oil then you would be draining the oil and resuing the filter.
Dorsai
Connecticut
Mar 30, 2006
#24
  • Mar 30, 2006
  • #24
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
Some reading material on filters. And I quote,
"Fram Extra Guard PH8A
This filter cartridge has a small outside diameter with a rather low filter element surface area (193 sqin), and features cardboard end caps that are glued in place. The rubber anti-drainback valve seals the rough metal backplate to the cardboard end cap and easily leaks, causing dirty oil to drain back into the pan. If you have a noisy valve train at startup, this filter is likely the cause. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak. The backplate has smaller and fewer oil inlet holes, which may restrict flow."
smueller
57
Wisconsin
Mar 30, 2006
#25
  • Mar 30, 2006
  • #25
Thats a pretty cool filter study. I go to school at MSOE and did not know they did that study here!
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Mar 30, 2006
#26
  • Mar 30, 2006
  • #26
I never do, always change both at 3-5k miles. I was just wondering what the additional benefits of using that filter would be besides better filtering which seems to be overkill for my car.
But it's all subjective I suppose. It's like me saying use Motorcraft instead of Fram because it filters better, but don't use FRPP even though it filters better than Motorcraft.
R
rconaway
1,415
Phoenix, Az.
Apr 1, 2006
#27
  • Apr 1, 2006
  • #27
One of the best filters is the Mobil 1 since it's not paper. There is a website that dissected every filter and analyzed them. Fram got exposed as a piece of crap. There is one other one that was pretty good but I can't remember off the top of my head.
http://www.ntpog.org/reviews/filters/filters.shtml
Stang2003GT
254
#28
  • Apr 1, 2006
  • #28
Im going to pick up the FRPP filter today and also try some Royal Purple.
Ill let you know how it goes.
the98stang
2,408
Clovis, CA
Apr 1, 2006
#29
  • Apr 1, 2006
  • #29
Stang|ess said:
Spend a few extra dollars and pick up a Motorcraft filter from your local dealership. Your car will thank you.
God, I remember when they were $3 at WalMart. Now Im paying $7 a pop . That's 8 tacos I could buy from JITB!
BHAHAHA.....I got my Motorcraft filer from Walmart for like $2.50
That Ford Racing filter looks dead sexy. Might as well buy it if you have the extra cash.
Stang2003GT
254
#30
  • Apr 3, 2006
  • #30
Got the filter!!!
It is very large and very expensive $14.99!!! I think its worth it.
merc123
420
North GA
Apr 4, 2006
#31
  • Apr 4, 2006
  • #31
Do this, run the filter for 5k miles and drain the oil. Keep some of that oil. Then run a regular filter and do the exact same thing. Which one is dirtier? I bet it won't matter.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Apr 4, 2006
#32
  • Apr 4, 2006
  • #32
i use motorcraft filters and castrol gtx
tag4car
Birmingham AL
Apr 4, 2006
#33
  • Apr 4, 2006
  • #33
i cut a fram extra guard in half and was quite suprised to see a majority cardstock structure in it, i was using wix, now i have a motorcraft on and havent noticed anything bad from it
joey
First Prev 2 of 2
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
