SOLD Ford Racing Short Throw Shifter And Bracket (m-7210-mgtb)
Ford Racing (aka Barton) Short Throw Shifter for 2011 to 2014 Mustangs with the MT82 manual transmission. This shifter will fit all GT's, V6's and BOSS Mustangs with the MT82 manual transmission. The shifter is used and in excellent condition with approximately 600 miles of shifting duty. There are no issues with the shifter, bracket, riser adapter or ball. See pics below. All hardware and installation instructions included. Would like to get $350.
Smoother, Firmer Shifts - By combining a Ford Racing MT-82 Short Throw Shifter and two post shifter bracket you will enjoy smoother, faster shifting while you're banging through the gears. This Ford Racing two post bracket and short shifter replaces the weak factory setup that can allow deflection during spirited driving and power shifting, causing slow or even missed shifts.
Retains Reverse Lock-out - The Ford Racing Short Throw Shifter was specifically designed to retain the Back Up Camera and the Reverse Lock-out safety feature of the 2011 and newer manual Mustangs to prevent accidentally shifting into reverse.
Ford Racing Quality - Machined from 6061 T6 billet aluminum and 304 stainless steel, for solid construction, this Ford Racing short throw shifter and two post shifter bracket installs easily with NO permanent modifications required to your Mustang.
Application - This Ford Racing shifter and bracket is specifically designed for the use on the 2011-2014 V6, GT and BOSS 302 Mustangs equipped with the MT-82 manual 6-speed transmission. Includes shifter, two post bracket and classic white 6-speed shift knob. Technical Note: The included shift ball and adapter only fit Mustangs originally equipped with a leather shift knob. Mustangs originally equipped with an aluminum shift knob will be required to reuse it, or install shifter boot part # BR3Z-7277-A
