OK Nate
That info makes more sense to me now
Bottom Line Here is
The EEC works likes it works no matter what method you use to make adjustments.
The various tuners we all use are nothing more than interfaces. You just have to pick the interface that you can best relate to and that is a good bit of what it all boils down to.
I have been thinking about what you are trying to do.
Lets talk a bit about this if you want to
Lets take this set of conditions to talk about for an example.
Steady cruise in say third gear at say 1500rpm
At that moment your load is gonna be very light
You then go to wot
Very quickly, like less than 1 sec, your load is gonna climb to something like 75% of its max load.
At this moment your rpm is gonna be about say 2k.
At this moment your tps is max
At this moment you will be in OL
Sounds like to me you have load, tps, and rpm to use in making your adjustments.
I'm gonna stop at this point and see if you think I'm on the same page as you are Nate
Grady
