found a place WILLING to align my car, but shims on a 69&TCP????
streetgrande69
976
Splendora, Tx
Alright, I found a place that is gonna align my Stang, it has a newly in stalled TCP power rack and pinion in it. 2 places so far have turned it away. Booth dual tone and beeline, both good shops with good reputations, so what’s up?
The place that Johns Mustangs suggests is Sam’s alignment shop. Ok cool, I call and talk to the guy; he's talking about using shims on the uppers like 65-66s. Does this guy know anything? Is it because the lowers have no cam? i thought the lower were still adjustable, because the 3 positions on the eccentric lower arm plates. Help!
maybe he is thinking it has TCP control arms or something. but i guess it is possible to have to use shims if they can't the camber right with the eccentrics being eliminated, it is still adjustable but not as much as it would be with eccentrics
Is this a common problem with the TCP rack conversion??? :confused: I'm assuming you have stock control arms but are using the TCP rack, right? Does the rack eliminate the stock eccentric, or are you using Pro-motorsports eccentric eliminator kit? If it's the Pro-m kit, mine came with special instructions for doing the alignment adjustments. I just took the car to a local place with the instructions and they aligned it no problem. Why does the TCP rack effect normal camber adjustment?
it does come with a 3 hole eccentric eliminator. 2 plates on each side and a bolt, is that like the pro-m setup? plus the inner bracket mounts in the lower control arm rear mounting location, bolted to the back of it. the brackets are slotted and allow for the additional movement.
it looks lik this, but 3 holes.................
I don't know if this is too far north for you (or maybe you could just contact them and pick their brain) but Glenn's Alignment does alot of Mustangs, SHelby club members, Cobra's, etc. The did my car both times. They even loaned me their aluminum template for the Shelby drop. Good guys. Ask to talk to alignment Dan (IIRC there are 2 Dans there).
Yep, that is similar to the Pro-m kit, so I don't know... Have you contacted TCP? Maybe they've got some insight. :shrug:
