Today i found a crack in my wonderful factory plastic intake. It was hidden but the thermostat housing. Cracked right on the lip where the thermostat sits at so that it wasn't a bad leak, just causing it to get past the rubber o-ring. But my real question is, I have been having problems with a miss in my engine. Sometimes i would do it all the time other times it was sporatic and only while on the throttle. Some mornings it would run like a charm. Other times it would run fine till i drove a ways. Do you guys think this could be caused by the coolant leak. I never let it get really low or the car run hot, but it was spraying on the drivers side coil pack and filling the front few spark plug holes with fluid as well. Please give me some opinions on what you guys have experienced in the past.
Thanks,
Jake
Thanks,
Jake
from their kit.
