- Dec 6, 2004
- 1,865
- 24
- 58
I wish I had a pic to post, but ill try to explain it.
On the inner side of the rear caliper where there is the column of spiraling brake lines, it seems like its leaking from where that fitting gets bolted into the caliper. It may be from a fitting a little higher up, but the brake fluid kind of puddles up on that bolt. I tried tightening it, and it was snug but I snugged it down a little more. Not sure that helped though. Anyhow... its been a while since ive added brake fluid, but its still slowly leaking. The car stops fine and everything, but I kinda want to fix it, since you know... the brakes are kind of importiant.
If anyone knows what im talking about, any advice would be great. I guess Ill pull that wheel off this weekend and give it a once over if I get the chance.
