Fox Body Throttle Body
88foxbodyowner
20
1988 Mustang GT
Alright so my car is basically all stock except for my exhaust (mufflers mainly) and some MSD ignition stuff. I want to get a cold air kit but mainly for looks because I know they don't do much but I also want to get a new throttle body and egr spacer. So I'm thinking 70mm. Is this to much, will there be some issues?
I'd do it as a package. Sn95 MAF with adapter, explorer intake, 75mm EGR spacer, convert the explorer 65mm TB for use on the mustang.
Prob under $200 for all that, and you'll feel it SOTP.
Save your money on the cold air intake. Stock airbox is fine just pull the silencer
Sent from my iPhone using Tapatalk
I also still need to do a maf conversion since my car is still speed density
For a stock headed engine, the biggest I'll go is 65mm. It won't have any affect on the speed density setup. If it was up to me, I would keep the 60mm throttle body. It flows plenty for the stock E7 heads. Besides the stock heads, the next major restriction that is even considered restrictive for the stock heads is the stock lower intake. The front two lower runners (#1 and #5) flow less than the average intake port cfm rating of the E7 heads. My dad ported the stock lower intake for my 91' and we followed this article: http://www.diyporting.com/intake_manifold.html He used a dremel to do the porting. I'm currently running a stock ported lower intake along with the stock untouched upper (flows enough for the E7's, even for stock gt40 non-p iron heads, so it did not need any porting), stock 60mm throttle body, sn95 5.0 70mm maf sensor and ford motorsport panel filter (made by K&N). I'm using the stock intake system, minus the air silencer. To be honest with you, my 91' has more grunt than my old 93', which had an Explorer intake manifold, 65mm throttle body and Pro-m 75mm maf sensor. Both of them are AOD gt verts with healthy engines and 3.73 gears. I remember being kinda disappointed when I did the Explorer intake swap on my old 93'. I picked up a decent amount of top end power and a bit more mid-range, but it felt like I lost some low-rpm power. Being an auto, it kinda sucked since it was my daily driver and the only way to enjoy the upgrade was to floor it and get the rpms higher into the rpm range. With the setup I have now, I felt like I picked up power across the board. The thing is that the smaller oval runners of the stock HO intake promote higher air-velocity and the overall design of the stock HO intake promotes a broader powerband compared to the explorer intake on a stock headed 5.0 engine. That is why Tmoss recommends the stock HO intake over the explorer intake for aod mustangs and/or convertibles (they are heavier).
Reactions: General karthief
