Fox Fox Door Armrest Bolt Issue
  • Thread starter Thread starter Black1987
  • Start date Start date Apr 2, 2022
First Prev 2 of 2
manicmechanic007
5 Year Member
Sep 26, 2017
2,544
719
143
Roy, Utah
Apr 3, 2022
#21
  • Apr 3, 2022
  • #21
limp said:
So did I when I was a Union Journeyman Auto glass installer circa 1974 to 1981..... I saw ALOT of bad motors that stopped working in the open or closed position of a door glass...... You could sometimes wiggle the glass and get the window closed for the customer until their new motor was received and installed...
That sure was the problem back in the day and we used to massage the armatures with emery cloth and then scrape the mica ourselves too
Not much anymore. Like I said if his armature has a bad spot it won't stick or stall only at the bottom
True it is harder to get the window moving up from the bottom and that might make your argument hold H2O
So to test that you could just see if it will roll your arm up and off (the water drains out)
Reactions: limp
manicmechanic007
5 Year Member
Sep 26, 2017
2,544
719
143
Roy, Utah
Apr 3, 2022
#22
  • Apr 3, 2022
  • #22
Good on ya limp
Where was that at? (the union shop)?
manicmechanic007
5 Year Member
Sep 26, 2017
2,544
719
143
Roy, Utah
Apr 3, 2022
#23
  • Apr 3, 2022
  • #23
So did you learn the one about the plastic drive failure?
With the 3 little plastic cylinders that break and disintegrate (that ford sold for 55.00)
That you can fix with 3 little ac caps?
Bree
215
87
38
Zanesville Ohio
Apr 10, 2022
#24
  • Apr 10, 2022
  • #24
So are you trying to get a standard socket in there, or are you using a deep well? Also, are you trying to get an imperial or metric on it, because I think it's metric, but that may also depend on what year you have to.
I think I used an 8mm deep well, 1/4in drive. Sometimes the 1/4 in sockets have a thinner wall over the 3/8.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,501
2,922
173
Florida
Apr 10, 2022
#25
  • Apr 10, 2022
  • #25
manicmechanic007 said:
Good on ya limp
Small shop in Eugene OR.,,,,,, circa 74-81......
Reactions: manicmechanic007
First Prev 2 of 2
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
