fox twin turbo kit
chevyguy15
14
minnesota
selling my twin turbo kit for a 302 based motor out of my fox body mustang.
pony down stage 2 headers
local speed shop cold side
pony down down pipes and other exhaust that bolt up to stock cat back ( 2 separate sections)
twin borg warner t04 62 mm turbos rebuilt 500 miles ago (no shaft play)
greddy BOV (type S)
turbonectic wastegates 38mm each (deltagate mark 2)
big intercooler with mounting brackets
feed and drain braided lines
all bolts nuts clamp and most gaskets included. all you need is fuel system up grades.
$2500.00 obo
located in nicollet, mn
only selling it cause i went to a bigger set up
I have a fuel injection setup including trick flow upper and lower, 30 lb injectors, 76 mass air, 70 mm throttle body etc. and a couple different cams + cash if u would want to work out a deal. Also have a powerdyne supercharger setup im looking to get rid of
