Planning my foxbody turbo build, just looking for some input. Here my parts list
-stock foxbody short block
·apr rod,main, and head studs
·new bearings
·full gasket kit
·new piston rings
·new water and oil pump
-explorer top end
·aftermarket spring
· 70mm sct maf
- fuel system
·aeromotive 340LPH
·60lbs ford ev6 injectors
·stock fuel rail
·100Psi fuel pressure regulator
- aftermarket clutch
-As for the turbo I'm going with the on3performance kit. I've made my mind up on that.
-I'm gonna be using triple x motorsports in Pensacola fl
Is there anything that I'm missing?
I want be starting the actual build till August because I'm currently on a tdy deploy
·new bearings
·full gasket kit
·new piston rings
-explorer top end
·aftermarket spring
· 70mm sct maf
- fuel system
·aeromotive 340LPH
·stock fuel rail
