A couple of weeks ago I had to replace my fuel preesure regualtor because mine started leaking. Got a BBK and I'm happy with it. (As a side note-I ordered it form Summit. Got it in two days (sort of). I got a ripped up/taped up box with just the catalog in it!!
Called Summit pissed and they sent another one out 2nd day air, and said they would settle up w/UPS. Great service from Summit.) TIP- get NEW screws when you have to replace yours. It's a bitc* to get to even with your upper intake off and the last thing you want is to be struggling with old dirty hardware. Three stainless steel screws $0.50 ea. BTW they are 10-32s NOT METRIC. The metric ones are VERY VERY close.
Overflow bottle boiling over- I did a search about this on this forum and got to thinking about my radiator cap. Sure enough, a $7 radiator cap solved this problem. However I discovered another problem. Now that my radiator is pressurized, I have (had) a hole in it. Replaced IT this weekend with the one jrichker recommended from Autozone. I had to do a little cutting and modifications, but got it to work.
As always,
THANKS GUYS!!
Called Summit pissed and they sent another one out 2nd day air, and said they would settle up w/UPS. Great service from Summit.) TIP- get NEW screws when you have to replace yours. It's a bitc* to get to even with your upper intake off and the last thing you want is to be struggling with old dirty hardware. Three stainless steel screws $0.50 ea. BTW they are 10-32s NOT METRIC. The metric ones are VERY VERY close. Overflow bottle boiling over- I did a search about this on this forum and got to thinking about my radiator cap. Sure enough, a $7 radiator cap solved this problem. However I discovered another problem. Now that my radiator is pressurized, I have (had) a hole in it. Replaced IT this weekend with the one jrichker recommended from Autozone. I had to do a little cutting and modifications, but got it to work.
As always,
THANKS GUYS!!
