frame help
  • Thread starter Thread starter cya_chevy
  • Start date Start date Apr 8, 2007
C
cya_chevy
galesburg illinois
Apr 8, 2007
  • Apr 8, 2007
ok i just got this car off my buddy its an 89 lx notchback it has a 302 lot of stuff done to it i just can see junkin it because the frame if i dont need to. but anyway he got in an accedent it tore off the front bumper and messed up the driver side fender and not to bad on the driver side but the hood hindges snaped i was just wonder i believe the frame on the drivers side from about the tower brace to the radiator is bent and i have a 89 lx notch parts car that has a good everything but it is not something i would want to put a motor in because i used so many parts on other stuff but is it possible to straighten the frame out or is it possible to take the driver side frame rail off the parts car and put it on to the wrecked car i know this may sound like a waste of time to try to fix but i just really would rather keep this can fix it if possible so any point of views or suggestions are apprieciated
thanks for the time
dan
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Apr 8, 2007
  • Apr 8, 2007
Cutting and welding in a new frame is a no-no for myself.
Check with your local body shop and see what THEY say about the frame. A lot of times bent frames can be corrected.
IMO, consider swapping over to the parts car. I know you said you dont want to beause you used a lot of parts off it already... but think about it like this: The parts car is now THE car and wrecked one is the donor. The donor should have all the parts u will need to complete the project (providing the donor is complete for the more part)
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 8, 2007
  • Apr 8, 2007
Wow, that was painful to read. I'm with poneypower89, if the parts car you already have is good, use it instead. You could probably get the other one fixed, but you'll now have the possibility of that frame rail becoming a weak point after being stressed and then welded, too. If the hood hinges snapped on the car you want to fix, chances are, you've got more work ahead of you with fixing the cowl and, or firewall, too. The only way to really know how much damage it sustained would be to get it on a frame rack and measure, but to be perfectly honest, merely having to ask about welding a frame rail to repair it means this car is basically toast if there is that much damage.
C
cya_chevy
galesburg illinois
Apr 8, 2007
  • Apr 8, 2007
sounds good thanks for the advice
dan
funkytrunk92
85
Indianapolis, IN
Apr 9, 2007
  • Apr 9, 2007
If the upper rail is not kinked or bent too severely then it will be able to be straighted pretty easily by a body shop with a frame machine. Check your door /fender gap, hood gap etc to see how bad the damage is. Also check for cracked seam sealer around the strut tower/firewall etc. If you can post some pics, I can tell you a little more.
smr
167
Nor*Cal (Vacaville)
Apr 9, 2007
  • Apr 9, 2007
tube chassis the wrecked car....
Resolved 83 frame rail damage?
  • x_man586
  • May 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 14, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
