The further we go, the further we must go. We are replacing rear frame rail extensions on our 66 coupe. Questions are:
Trunk floor replacement - We'd like to go with a fuel cell, rather than replace the tank. Most of the floor, except the tank flange, needs replacing. Thinking about cutting out entire floor, including tank mounting, and just weld in a flat piece of steel, then use fuel cell. Does this idea work?
The rear bumper supports appear to be tack welded to the floor. The old rear frame rails are immediately below. If we cut the welds on the bumper mounts - hopefully to save them - would the old frame rails and floor drop away, or is the frame rail welded to the steel frame below the tail light panel? Not sure what that part is called.
Hoping to get the old frame rails out with a minimum of damage to other parts. Thanks.
