the framerails are pretty much gone what is an easy fix or should i try welding new section in or complete front replacement i have a donor car that is mint
I agree, if it's something you can do, and if you want to really build the car, you can just pull the drive train and take care off all the under body rust, all engine bay rust and rust proof/paint it, if i had a way to pull th engine, that's what i'd do..Flavadave4 said:cut out and weld in new pieces from donor car. make sure everything is sqaure when you weld and tack first so nothing warps
billison said:You'd have to call around, a idea you might want to concider is cutting the t-top roof off and putting it on the mint car, and swap the doors, just a idea. i bet the t-tops is sweet...
