  • 1994 - 1995 Specific Tech
Free Mods
  • Thread starter Thread starter randomjoker
  • Start date Start date Mar 22, 2004
First Prev 2 of 2
Jerry Leaming
477
Olympia Wa
Mar 23, 2004
#21
  • Mar 23, 2004
  • #21
synthetics always good for some Hp and ET.
I know its not free but you have to change your fluids anyway..........
MontrealFive0
167
Montreal, Quebec
Mar 23, 2004
#22
  • Mar 23, 2004
  • #22
true blue,
i've asked about this before about dogbones......i took it off, but i didnt realize i was supposed to leave that bracket dilly thing on. My car bottoms out everywhere now. why will i have to buy new bolts to put in back on?
caffinecobra
61
Sacramento, CA
Mar 23, 2004
#23
  • Mar 23, 2004
  • #23
Where's the 25lb fender weight on verts?
9
95.0Stang
538
Kansas
Mar 23, 2004
#24
  • Mar 23, 2004
  • #24
Front passenger side I think!
caffinecobra
61
Sacramento, CA
Mar 23, 2004
#25
  • Mar 23, 2004
  • #25
is it on late models, too? I've never heard of that!
95GTvert[bv12]
1,792
Lake Tahoe, NV
Mar 23, 2004
#26
  • Mar 23, 2004
  • #26
All verts cobra or not 95-newer its in the passenger fender....after you remove that your only 125lbs heavier then a comparable coupe
caffinecobra
61
Sacramento, CA
Mar 23, 2004
#27
  • Mar 23, 2004
  • #27
wow, thanks! so why is it even there???
95snoozer
2,572
RCR
Mar 24, 2004
#28
  • Mar 24, 2004
  • #28
to prevent cowl rock form the motor... a type of balancer
TrueBlue95GT
966
Connecticut
Mar 24, 2004
#29
  • Mar 24, 2004
  • #29
MontrealFive0 said:
true blue,
Ya, I had the same problem with bottoming out after removing it. All you need are two shorter bolts and it solved all of my problems. Nothing has to be custom made. Just get two shorter bolts that have the same thread and it will work.
caffinecobra
61
Sacramento, CA
Mar 24, 2004
#30
  • Mar 24, 2004
  • #30
Does it make a big difference removing it? As far as balance goes?
95snoozer
2,572
RCR
Mar 24, 2004
#31
  • Mar 24, 2004
  • #31
no
and you have to put a bracket back in the rear? mine is gone
MontrealFive0
167
Montreal, Quebec
Mar 24, 2004
#32
  • Mar 24, 2004
  • #32
my bolts are still in the dogbone, with busing like things. I take em out and just bolt em through the bracket??? If you could get me a picture of your bracket on, that would be really helpful. THanks
TrueBlue95GT
966
Connecticut
Mar 24, 2004
#33
  • Mar 24, 2004
  • #33
95 snoozer, I noticed a problem of the rearend banging on the bottom of the car when hitting little bumps because my car was lowered. That's why I had to put the bumper stopper on the top back on.
MontrealFive0, you should take one of those bolts out of the bushings. A hammer and WD40 will work fine. Take that bolt to a hardware store and have them find the type of thread. Get two more bolts with that type of thread that are only two inches long instead of humongous and some washers to fit those bolts. Then, you go to your rear end and take the bracket with the rubber piece on top of it and bolt it back to the rear end with the new hardware. Sorry no pictures while I'm at college.
ProKiller
3,064
15
78
PA
Mar 24, 2004
#34
  • Mar 24, 2004
  • #34
Free/cheap mods
1. Ignition Timing(advance timing, usually 14*)
2. Adjustable Fuel Pressure Regulator(richen the fuel)
3. short belt(bypass a/c, power steering)
4. remove air silencer
5. filter
6. Underdrive pulleys(not really expensive if u do yourself)
7. remove pass. seat, back seat, trunk lining, dogbone, spare tire and jack
8. relocate coolant overfill to the washer fuild tank (95snoozer)
9. general tune up
10. go on a diet to lose driver weight...
all i can think of
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Mar 25, 2004
#35
  • Mar 25, 2004
  • #35
ProKiller said:
Free/cheap mods
this short belt, how much power does that free up? do you use it only for the track?
TrueBlue95GT
966
Connecticut
Mar 25, 2004
#36
  • Mar 25, 2004
  • #36
The short belt frees up around 10hp to the rear wheels. I wouldn't recommend using it on the street though. You have no more power steering.
BlueOvalStangGT
2,849
Mar 25, 2004
#37
  • Mar 25, 2004
  • #37
what size belt is it? do you put it on at the track or do you just drive w/o p/s? my a/c doesnt work anyways so how much could i get by bypassing just that till i get a new hose?
DCjuggalo
169
Charlotte, NC
Mar 26, 2004
#38
  • Mar 26, 2004
  • #38
how to lighten a mustang...
http://www.wildhorsesracing.com/projects/stanglite.html
First Prev 2 of 2
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
New Foxbody diagnostic tool ;)
  • nicholase
  • Apr 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
DadLife0724
O
WTB Looking for an SCT X4 tuner for my 2005
  • optionizerSS
  • Jun 8, 2026
  • Want to Buy
Want to Buy Jun 8, 2026
optionizerSS
O
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
