I recently rebuilt my block, and anyways I used a Clevite kit for all the plugs. When I installed them I also used a slight coat of Ultra Black silicone around the edges as suggested by a few people. Well I finally got to start her up and each and every one (6) leaks slowly, more like 'seeps'. Enough to make a wet spot on the driveway after 30 min running. Two I can see little drops form until they drip, the other four feel a little wet when I inspected them.
Questions are...How far should they be put into the block? I've got them about 1/16" below the hole's machined surface....
Should I use any silicone at all?
Do you think they will seal themselves up over time? ....far fetched...
I'd hate to pull the motor again, but if I have to.....$*!%
