I installed a set of SVO calipers this weekend and now I have a softer pedal. Is this because I have to push more fluid into the caliper to acheive the same brake capability? If so, which master cylinder should I use? I have rear drum brakes right now but hopefully I'll be stepping up a little later? Should I get the one I'm going to need for the 4 wheel disc setup and just put a proportioning valve in so it doesn't make the rears lock?
thanks, Larry
thanks, Larry
