  • 2005 - 2009 Specific Tech
FRONT CLEAR CORNERS~~~INSTALL???
  • Thread starter Thread starter vitesse06
  • Start date Start date Sep 21, 2006
V
vitesse06
49
  • Sep 21, 2006
just ordered a set of the black housing clear turn signals.....any advice on the easiest instalation would be very much appreciated.
is it necessary to remove the wheel-well lining?
thanks in advance.
M
mikes06gt
47
  • Sep 21, 2006
the driver side is not that bad...the passenger side you have the windshield washer resevoir to deal with..be prepared to fight with them and get frustrated because it is a tight fit but i put mine on a couple of weeks ago with the hyper-white bulbs and it was so worth it...put the hid head and fog lights and you will be very pleased
cowtown
228
Victoria, BC Canada
Sep 22, 2006
  • Sep 22, 2006
The only thing I had to fight with was the fender splash guards. Once you get those out of the way/removed the rest is really easy.
I'd just make sure you have a long flat head screwdriver, a plastic bit for prying the splash guard and some needle nose plyers.
The screwdriver helps when releasing the clips on the lenses and the needle nose (or pliers) are needed to squish the clip, using the screwdriver after you have one released keeps the lense from popping back on while you get in position to release the other one.
I didn't have any problems with the washer res, it just reduced a little bit of hand room but like I said I had to fight to get the splash guards out, but patience and that plastic flat prybar type thing helped there.
ShowYa06
144
Kansas City, MO
Sep 22, 2006
  • Sep 22, 2006
I took the entire cover off and it was a snap
anthony05gt
1,262
Maryland
Sep 22, 2006
  • Sep 22, 2006
That's the easiest way.
O
orange07gt
58
  • Sep 23, 2006
where did you guys buy these..... I don't want to buy just any... I had Honda's in the past and the ones that everyone had would fill up with water and look crappy. I want a nice set... Thanks
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Sep 23, 2006
  • Sep 23, 2006
sounds like APC lenses.....
anthony05gt
1,262
Maryland
Sep 23, 2006
  • Sep 23, 2006
I hear the quality isn't that good. Am I wrong?
O
orange07gt
58
  • Sep 23, 2006
You got that right..... So.... which ones are good quality for our cars??
bigcat
May 1, 2005
3,015
7200 feet
Sep 23, 2006
#10
  • Sep 23, 2006
  • #10
APC = Always Produces Crap i have NEVER seen a single APC light that was quality.
if you can find it TYC is one of the best manufacturers of aftermarket lighting products that i have found. fit is great, and they dont leak.
V
vitesse06
49
#11
  • Sep 23, 2006
  • #11
i bought mine of mustangtuning.com............they look pretty good quality to me but then again they havent been on the car very long....i will let you guys know if they fog up.
-vitesse06
pudgy2342000
43
RI
Apr 11, 2012
#12
  • Apr 11, 2012
  • #12
I put a clear 3M film over mine. also i peeled the lining out just a bit and it was a breeze. however i didnt have a small enough screw driver and running 20's called for removing the front wheels. but still 30 mins and i was done
GoneFord
115
#13
  • Apr 12, 2012
  • #13
Royal pain in the forearms for me. I refused to take the wheels off and didn't want to mess with the splash guards. I ended up removing three or four splash guard retaining screws and pulled it back. The passenger side was a major pain because that's where the cold air intake track runs for the KB.
I'm really pleased with the subtle appearance change they provide.
I bought mine from ModifyMyStang.com and including bulbs it was $75.50. Can't speak to the long term quality as they've only been on the car a month or so. They look exactly like the originals, but lack a DOT number...
pudgy2342000
43
RI
Apr 22, 2012
#14
  • Apr 22, 2012
  • #14
Im pleased with mine. Im also running putco white 360 LEDs
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
