Since I have to take the struts out to install my coil-overs, I might as well replace the stock struts that are in there now while I'm in there. Which struts should I get?
Note that this is only for the FRONT; I am leaving the rear as is.
Note also that the manufacturer says that these coil overs WILL NOT WORK with Biltsteins.
Thanks in advance, Chris.
) I was looking at coil overs as a possiblility, hence the MM plates.
