Front Coil spring install!
  • Thread starter Thread starter jackchan
  • Start date Start date Mar 20, 2006
First Prev 2 of 2
Rick 91GT
Mustang Master
95
99
PA
Mar 22, 2006
#21
  • Mar 22, 2006
  • #21
You can also take them to a local BIG Rig shop and have them compressed and steel banded, then all you have to do is put them, get it all back together and cut the bands loose...
Never done it but have heard a lot of guys that do it.
I usually never use a compressor to remove springs, but I always use it to install the fronts, rears you can do with out them.
soylentgreen
102
Mar 22, 2006
#22
  • Mar 22, 2006
  • #22
My advice...use the spring compressor to remove and install front springs. I'm afraid that, yes, the spring can pop out of there and nail you.
slvrvert91
#23
  • Mar 22, 2006
  • #23
Can you rent them from an auto store? I am removing steeda sport springs, and installing Bilstein Coilover kit, will I need a compressor? I have taken the rears off before and that was not a problem, I just have never done the fronts. Thanks
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 22, 2006
#24
  • Mar 22, 2006
  • #24
I tried every place in the phone book including the big rig places and there was no one that would band springs for me, that was the point where I finally invested in the proper spring compressor, it made the job safe and easy!
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Mar 22, 2006
#25
  • Mar 22, 2006
  • #25
I tried the spring compressor......good luck with that.
the spring compressor will help get it in but then you got to figure out a way to remove the spring compresser from the spring while having the spring loaded. not safe. it takes forever and alot of hand torque to use the compresser's too.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 22, 2006
#26
  • Mar 22, 2006
  • #26
If you have the Correct Compressor the spring goes right in and the compressor just slips right out when you are done, very easy!
Mavrick
2,264
Collingwood, ON
Mar 22, 2006
#27
  • Mar 22, 2006
  • #27
You won't need a spring compressor..
K
ka0tyk
1,610
Los Angeles, CA
Mar 22, 2006
#28
  • Mar 22, 2006
  • #28
if the coilovers dont come pre-assembled you will need a spring compressor so that you can install the spring over the strut so you can get the adjustment and locking rings on. it will be like 2" too long and theres no way you can compress a spring that much on your own. coilovers are a different story.
slvrvert91
#29
  • Mar 22, 2006
  • #29
The kit should arrive tomorrow, so I will check it and possibly still have some questions. So if the coilovers are pre-assembled, I shouldn't need a compressor? I am very anxious to get this full kit on my car. Thank you for the help
First Prev 2 of 2
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
