front coilover lbs
  • Thread starter Thread starter rednotch88
  • Start date Start date Apr 25, 2009
1 of 2 Next Last
R
rednotch88
151
CHICAGO
Apr 25, 2009
  • Apr 25, 2009
Noob question...but what are the determining factors when choosing your front coil over springs..choice options on AJE are 150,175,200,and 225lb springs.
Shed some light on the subject for me please.
EPIK
796
LEFT COAST
Apr 25, 2009
  • Apr 25, 2009
150-175lbs are great for drag racing setups, & are most likely very soft during street use, similar to stock 4 cylinder springs. the 200-225lb springs are going to be a little firmer, but will still work well at the track...
Just as an example for you, my maximum motorsports front coilovers are 325lbs, & they are similar to an H&R supersport spring. They dont offer much weight transfer, but they handle & ride great on the street...
R
rednotch88
151
CHICAGO
Apr 25, 2009
  • Apr 25, 2009
glad you posted I been reading all your other threads.
So which spring would you recommend? it is a track only car seeing very little street use.Do track cars like firm springs or a softer type.Also what strut will best fit the AJE setup I noticed it comes with everything,but the struts...
thanks for the fast reply
EPIK
796
LEFT COAST
Apr 25, 2009
  • Apr 25, 2009
rednotch88 said:
glad you posted I been reading all your other forums.
Im no expert on drag racing setups, but I think the softer the better. I think lakewoods, or strange adjustables are the best setup for drag race coil over setups... I would recommend the 175-200lb springs...
ChromdOutDubs
268
Tavares, Florida
Apr 25, 2009
  • Apr 25, 2009
Im running a #110 QA1 spring on my drag car. My car only weighs #2700 so that could change a lot between mine and yours.
-AJ
R
rednotch88
151
CHICAGO
Apr 25, 2009
  • Apr 25, 2009
Sorry to your guys pain in the Di*k of the day,but
can you link me the Shock setup(strange and lakewood) for the AJE kit. I cant seem to understand how it works with coil overs nor find them.
thanks again
ChromdOutDubs
268
Tavares, Florida
Apr 25, 2009
  • Apr 25, 2009
Check you PM i just linked you to Strange Struts and the Lakewoods 90/10's
R
rednotch88
151
CHICAGO
Apr 25, 2009
  • Apr 25, 2009
so the sleeve for the coil over slides down the shock stem then screw the coil over perch on for spring to rest on?you can basically use a stock shock then? correct? there really isn't anything special except for it being a performance shock?
Thanks
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 26, 2009
  • Apr 26, 2009
are you looking for drag or race setup, i have my car setup for road racing and front rates for my car is 500, rides great on the track pretty stiff on the street, but i like it.
R
rednotch88
151
CHICAGO
Apr 26, 2009
#10
  • Apr 26, 2009
  • #10
Its going to mostly drag.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 26, 2009
#11
  • Apr 26, 2009
  • #11
then softer the better, now i know my car is a walking MM ad but i do really believe in their products, and they will always stand behind them no matter what, quality is second to none, only downside is the price
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 26, 2009
#12
  • Apr 26, 2009
  • #12
I'll check and see what my buddy is running...his seem to be too stiff but they're supposed to be a drag spring/shock setup. His is so firm that when you sit on the fender it barely goes down at all and he has very little weight transfer.
R
rednotch88
151
CHICAGO
Apr 26, 2009
#13
  • Apr 26, 2009
  • #13
Now I heard two different things now one side said real soft and now i'm hearing more stiff.
Let me know what your buddy setup is 85_SS....
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 26, 2009
#14
  • Apr 26, 2009
  • #14
He said he's pretty sure they're 150s but his car is also really low which might be part of it.
R
rednotch88
151
CHICAGO
Apr 26, 2009
#15
  • Apr 26, 2009
  • #15
so what do you guys recommend me getting?I don't know what to get now.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Apr 26, 2009
#16
  • Apr 26, 2009
  • #16
Depends on the weight of the car. Mine are 150's because I knew it was going to weigh around 2900 lbs.
R
rednotch88
151
CHICAGO
Apr 26, 2009
#17
  • Apr 26, 2009
  • #17
my car has 10 pt cage,thru-floors,no heater box,no a/c,no p.s,fiberglass front clip(fenders/bumper),fiberglass hood,rear of dash has been gutted,No sound deadening material in car,AJE front K member.I believe it is going to be very light.
What do you think will work for me and be on the safe side?
faststang90
522
baytown texas
Apr 26, 2009
#18
  • Apr 26, 2009
  • #18
i had 175 in my car when i was installing a bbf. the front of the car was to hard to move when i changed my combo to a 351 (427). i inatalled a set of 130 in the car. i was bored the other day so i took the truck and trailer to the scales of 18 wheelers and then loaded the car and went back the car was 1850 with out a motor or tranny,etc
R
rednotch88
151
CHICAGO
Apr 26, 2009
#19
  • Apr 26, 2009
  • #19
Who was the spring manufacturer?AJE only goes as low at 150lbs in their kit.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Apr 26, 2009
#20
  • Apr 26, 2009
  • #20
Sounds like 110's or 130's.
1 of 2 Next Last
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
