  • 2005 - 2009 Specific Tech
Front Fascia - anyone dont the replacement themselves?
  • Thread starter Thread starter gp001
  • Start date Start date Feb 9, 2006
G
gp001
4,401
So. Cal.
Feb 9, 2006
  • Feb 9, 2006
I am replacing my front fascia and need to know how to remove the rear most nut attching the fascia edges to the fender. Do you need to completely remove the inner wheel well to access this nut?
I tried searchig, but all the resuts were more about what people have done or want to do, but not how they did it
Thanks in advance
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Feb 9, 2006
  • Feb 9, 2006
i have nerver completely removed the inner splash shield from any car i have worked on, at least when removing the bumper. it usually just pulls out of the way enough for access to the bolts/retainers.
M
Madhouse
201
Houston, TX
Feb 9, 2006
  • Feb 9, 2006
just take out the 3 screws holding the front fascia to the inner fender liner, then pull the liner back to reach the two nuts holding the fascia to the car (on each side)
then remove the 4 little (5.5mm) bolts on the underside of the fascia where it attaches to the splash guard
then take out the two bolts holding the fascia down to the front clip and slide it forward off the car - unplug the fogs and corner marker lights and it comes right off
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Tuesday at 11:55 PM
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Tuesday at 11:55 PM
dmw_4814
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
