Front springs
Mustang67Coupe
64
Salem, Or
Hey guys, ive got a 67 coupe and it has 428 big block springs in it... Im putting a small block in (289,302 block). Should i replace them with something like a 620 or take the springs and cut them down to my desired ride hight? If i do cut them down how would it handle, shift weight and all that stuff?
Sorry if i didnt supply enough info, thanks for your opinions guys! :D
The car had a 428CJ in it before i bought it, then he removed the enigine before the sale, couldnt blame him with that engine, and it saved me alot of money for the car without the engine..
Mustangs are better with small blocks in my opionion anyway
The 620s are nice, and made for your application. They aren't very expensive, and much easier than screwing around with cutting. I am an advocate of cutting only when there are no other options available.
I would put the new motor in, drive it and see if you like how it feels and looks. The 620s will be a stiffer-harsher ride than the orginal springs. You may want to got with stock replacements or some 540s. Also you can always go with a softer spring adn a stiffer shock
I went with 620s to hold up the weight of the 429 After playing with Mustangs for 20 years I have found it is best to do one major thing at a time.
Cheap indeed, I paid $96 for my pair (that's like what $48 per spring?)
Don't cut, you'll be plenty happy with the results of the 620s.
