Front Springs
  • Thread starter Thread starter FordGuy88
  • Start date Start date Sep 14, 2007
F
FordGuy88
241
Park Ridge, IL
Sep 14, 2007
  • Sep 14, 2007
Hey guys Im having a hard time putting in my new front springs. I have done this before(in my last car). Last time I put a jack under the A-Arm and un-bolted the two bolts in the back of the A-Arm, let the jack down slow, took out the old spring, and put the new one in. But this time the bolt is stuck in the A-Arm. I cant get it out for the life of me. Any sugestions would be great. I have tried putting the A-Arm in every angle to get the bolt out but it is just stuck in there. I have already come to the conclusion that it is the bushing that is holding it in there. I have tried liquid wrench and the bolt is currently about a half inch out. Any help please.
Thanks,
Dave
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 17, 2007
  • Sep 17, 2007
I can't help you with any ideas mate. Maybe a long drift and a hammer?!?!? Hope you have the job done already though.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 17, 2007
  • Sep 17, 2007
had a similar problem yesterday. find a wrench close to the size of the diameter of the bolt stick it on the shaft of the bolt and beat the handle of the wrench.
cenok is family
1,409
69
79
Norman, Ok
Sep 17, 2007
  • Sep 17, 2007
you're doing that the hard way man. disconnect at either the top of the strut or bottom, (you'll need a ball joint seperator too), let down on the jack and the a arm will pivot down at the 2 bolts you're trying to take out and the spring will come out. reverse to put back in. it's how i've always done it and i've never had ANY problems.
the pony boy
358
Sep 17, 2007
  • Sep 17, 2007
theres a good thread on here about a guy using 4" pipe clamps and looks like the way to go.if you search im sure it will come up. phil
HISSIN50
34
129
Sep 17, 2007
  • Sep 17, 2007
I'd want to fix the seized bolt situation rather than just do a work-around.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 18, 2007
  • Sep 18, 2007
Common problem. Do you have air tools?? What I do is use an impact.....clockwise...then counterclockwise....keep doing this back and fourth until the bolt comes out. It works every time. Or you could get an air hammer and hit it with that. I had this problem last night, and this is what got me out of a jam.
F
flyingtexan
57
Washington Twp, Michigan
Sep 18, 2007
  • Sep 18, 2007
Not sure what springs you've been putting in....probably lowering springs or stockers....try road race springs.....your idea aint going to work.
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
N
SOLD FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Nov 10, 2026
nfilut43
N
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
