front springs
I'm getting closer to sorting out the new suspension for my 65. I'm wanting to go with 1" lowering springs in the front, mid eyes in the rear. Looking at the springs, there's 1" GT and 1" 560lb also progressive rate ones but I don't know if they are lower? This is all from Opentracker if that matters. Not sure what the difference is in all this, want a nice handling, nice stance car. I'm thinking the GT ones would suffice although I do like the idea of the progressive if they provide the 1" drop I want. Any thoughts on this would be appreciated.
I would contact John at OTR and ask the difference in the two springs, he's a great guy and won't steer you wrong or sell you something you don't need. I put 1" drop 560's and mideye leafs on my '67 and it came out level fr/rear w/in 1/4". I also did the 1" shelby drop at the same time but it only brings the front down 1/4-1/2".
Jon
Jon
Thanks Jon, I'll do that
I have 550# 1" drop springs on my front and they work really well and it sits nice and low with the Shelby drop too. The only thing I had problems with was figuring out what tire size to run with my 17s since my 245/45s rubbed a bit.
I talked to John at OTR and for my purposes he recommended the GT 1" drop springs. Tire size will be an issue I need to deal with later on. What did you settle on? I was thinking 235/45 on the back and 225/45 on the front but I wouldn't mind bigger if they fit, are the 245/45's ok on the rear?
Yeah I think those are the springs he recommended to me too. They work really well. I've got 225/40s on the front and 245/45 on the back. The back tires scrape just a tad when I hit a low spot in the road but I'm going to try to roll the rear fenders hopefully. If I could do it again I'd probably run a 235/45 on the back just so I could drive a little harder. Some guys have been able to run 245/45 all around, but I have had some issues when I tried, so I bought new front tires and have 2 spares now for the rear.
Thanks for the tire info, sounds like the 235 rear, 225 front is the best bet. I have a lowered truck that does the rub here and there if it's overloaded or hits a dip in the road. It bugs me plenty so I don't want to go there again.
Did you already do the Arning/Shelby drop on the upper control arm ? That will lower the car a bit and give you better geometry. Maybe talk to John about that and see if changes his spring recomendation.
I haven't done it yet but I ordered the template as well from John so it was taken into consideration. The car isn't going to be raced so the real goal is to make it handle better without giving up too much ride quality. Also to drop the stance a bit, so rear mid-eyes and 1" lower springs in front and a bunch of other goodies :D
