Front Suspension Mounting Hardware
  • Thread starter Thread starter 1967project
  • Start date Start date Sep 14, 2011
1967project
89
Oklahoma
Sep 14, 2011
  • Sep 14, 2011
Purchased a Grab-a-Track front and rear suspension kit for my 67. The last shop that I had it at put the rear on, but not the front. The kit did not come with any mounting hardware for upper/lower control arms to the body/frame.
The suspension is with me, the car is 100 miles away at a media blasting shop with no front suspension on it and I have to put it back on.
Does anyone out there know the sizes (lenght/ thread for the following hardware (guessing it should be same as stock, cannot find info on stock part numbers I have):
Upper control arm washers & nuts
Lower control arm to body bolt, washer, nut
Thanks.
JonK
276
Nashville (Smyrna), TN
Sep 15, 2011
  • Sep 15, 2011
I'll have to check the UCA nut size when home but the LCA frame mount (bottom of shock tower) is a bolt with an eccentric (egg shaped washer) on it to adjust camber. You could switch to an eccentric eliminator kit like this, if you're having to buy it all anyway, eliminates chance of camber change due to eccentric loosening and rotating:
Opentracker Racing Products - Lower Control Arm Camber Kit
Jon
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
