i have realized for some time now that there is a problem something in my front suspension. every time i go in and get an alignment and get my tires balanced and rotated it only takes a little while until my steering wheel starts wobbling again. the faster i go the worse it gets. also, there seems to be quite a bit of play in my steering wheel but maybe that's normal. i can hear a popping noise at low speeds when turning hard from the front end which i hear is the balljoint going bad. i opened up my haynes manual and it said that i couldn't replace the balljoint without getting a whole new control arm. is this true? also, could my tie rod ends be suspect here? and should i replace both the innner and outer tire rod ends? i replaced the steering rack a while back and i noticed that the steering rack bushings could be in better shape. i'm just about to start college so i'm extremly limited in what i can spend so what could i do for relatively cheap that could solve most of my problems?
