front swaybar wins... :(
  • Thread starter Thread starter No.11
  • Start date Start date Oct 12, 2011
No.11
614
10
48
Los Angeles
Oct 12, 2011
  • Oct 12, 2011
last night I got out late to try and put in my front swaybar with my new prothane end links and frame bushings. well, I failed miserably as I could not get the endlinks aligned once the frame bolts were on. yes I left them loose. I had the jackstands sitting under the a arms... is that not a good spot for them? do I really need ramps for this job? or where can I put them to mimick regular ride height?
also, what is this x brace? i could not locate it on the picture of the suspension in my Haynes manual. it bolts to the middle of the k member, then to some plates under the driver and passenger door, and then on each side under the front bumper. is it some kind of aftermarket k member brace? thanks!
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 12, 2011
  • Oct 12, 2011
Im guessin your car is a convertible?
No.11
614
10
48
Los Angeles
Oct 12, 2011
  • Oct 12, 2011
Nope, hatchback. I read about a convertible x brace, but I could only find info about that for sn95s. So is this x brace really doing much in my hatchback, or should I just remove it?
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Oct 12, 2011
  • Oct 12, 2011
I guess it's extra strength but it's hard to tell if they are really sturdy bars or not. Front sway bar and end links is not a job you run out and do quickly especially at night. I ran into problems with those damn endlinks too. Couldn't get the top nut on there.
No.11
614
10
48
Los Angeles
Oct 12, 2011
  • Oct 12, 2011
aint that the truth! i read that it could be done in less than an hour. I fugured with my slowness and learning curve, it would maybe take me 2. Couldn't do it. I hope my car's frame is straight...
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Jacking up driver side
  • Scrapla347
  • Sep 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 26, 2024
CassieL
