  • 1994 - 1995 Specific Tech
Frozen Brake Lines
  • Thread starter Thread starter BlackStang95
  • Start date Start date Jan 13, 2008
BlackStang95
97
  • Jan 13, 2008
I'm installing stainless lines on the rear of my car. However, one of the factory lines is frozen and the nut is starting to round. I have sprayed the nut with PB Blaster, but it is not working. Does anyone have any ideas?
Thanks!
HISSIN50
34
129
Jan 13, 2008
  • Jan 13, 2008
Is it too rounded to use a line-wrench (if you have not been using one already)?
BlackStang95
97
  • Jan 13, 2008
Unfortunately, I have been using a line wrench already. I read online that to try and use a pair of vise-grips on the line wrench to give it a tighter fit. I'll be trying that later today..
95strokerPSU
986
Sacramento from Philly
Jan 13, 2008
  • Jan 13, 2008
Make sure you spray it down with power lube and then try the vise grips.
Bosko5.0
1,067
longwood, FL
Jan 13, 2008
  • Jan 13, 2008
tap the nut with a hammer a couple times to break the seal.
BlackStang95
97
  • Jan 13, 2008
Well...we got it off...my friend has a friend of needle-nose vise-grips that open and close "parallel". Got those suckers on there good and it finally broke loose.
Thanks for the help!
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
Sponsored New J&M Release: 2024+ S650 Full Front + Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
