FRPP Differential cover - use teflon tape on all plugs/bolts?
Ghost001
398
California
Hello,
I'm getting ready to remove the stock differential cover for the first time, and install a new FRPP differential cover.
I have zero experience with differentials or gears or anything inside the pumpkin.
Should I put teflon tape on all of the bolts, including the fill plug, drain plug, and the 10 outer bolts? Otherwise, will it leak? Someone else suggested silicone. Did they mean the glue stuff, like what people use as the gasket for the stock differential cover, or did they mean some sort of oily substance?
Is there anything else I need to watch out for?
I've got an FRPP gasket, so I'm not going to use sealant, just the gasket.
You could probably use Teflon tape, but I don't think it's necessary. When I replaced my diff cover I used gasket maker and made sure I torqued all bolts to spec.
Make sure you torque them all evenly when installing the new cover, otherwise you could twist the cover and it won't seat properly - hence leaks. With the aftermarket covers it's nice to have the fill/drain plugs on them - install the cover right the first time and never have to take it off again.
Jay
