FRPP Shortie Headers
  • Thread starter Thread starter 89GT5foHO
  • Start date Start date Oct 14, 2005
89GT5foHO
  • Oct 14, 2005
Hi, I picked up my GT about 3 months ago and have been putting it together.
Right now the engine and exhaust is stock and I want to put an aftermarket setup on my car.
Will Ford ceramic shorties bolt onto the stock heads without leaking. I read they fit GT40 heads and I want to be sure they bolt onto the stock heads before I buy them?
I'm also planning on a Flowmaster American Thunder cat-back and an H-pipe with hi-flow cats? Any recommendations on a brand of H-pipe?
Thanks for reading.
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Oct 14, 2005
  • Oct 14, 2005
I believe the FRPP shorties will work. That's what i have on my stock heads. But i don't have the ceramic ones. I ran 2 1/2inch exhaust all the way out. Also, for your h-pipe, i run a BBK h-pipe. It was pricey, but better than stock, especially when you need better flow later on with mods.
89GT5foHO
  • Oct 14, 2005
You "believe" they will work, and that's what you have on your stock heads
Did you mean, you know?
blu93gt
San Diego, CA
Oct 14, 2005
  • Oct 14, 2005
I had the ceramics on my stock heads and now on the Trickflows and I didn't have any problems. Make sre you get good header bolts though.
darthcual
985
Arlington, TX
Oct 14, 2005
  • Oct 14, 2005
Should work on their but nothing is a sure thing if thats what your asking.
89GT5foHO
  • Oct 14, 2005
darthcual said:
Should work on there, but nothing is a sure thing, if thats what you're asking.
I think I meant to ask if they were maybe designed to kind of fit onto possibly the stock heads if that is perhaps feasible.
cevtv
1,113
Massachusetts
Oct 14, 2005
  • Oct 14, 2005
Yes, they will fit.
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Oct 14, 2005
  • Oct 14, 2005
what i meant is they will fit.
SamSnyder
196
  • Oct 14, 2005
My BBK 2.5" high flow catalytic convertor h-pipe fit like crap. It didn't want to line up and the LX tailpipes ended up being all cockeyed when I did get it bolted up. I had to pay a muffler shop to rebend a bunch of stuff to get the tailpipes straight, and when I contacted BBK about it, they were largely indifferent. Also, the BBK was quieter than the blown Steeda 2.5" cat h-pipe I took out (and which fit like a glove), which may or may not be better (the cats began to rattle internally, indicating broken guts). It was definitely the BBK that was not bent right, since both the stock h-pipe and the Steeda fit perfectly, with the tailpipes at the right angle. I think the Steeda was actually manufactured by Moreflow, judging by its looks. I probably would not get another BBK.
89GT5foHO
#10
  • Oct 14, 2005
  • #10
Thanks for the help
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Oct 14, 2005
#11
  • Oct 14, 2005
  • #11
04sleeper
2,674
14
89
Dallas, TX
Oct 14, 2005
#12
  • Oct 14, 2005
  • #12
FRPP headers will fit just fine. If you car is still stock with stock heads I suggest sticking with the factory headers. You WILL loose power if you put on the FRPP's, I can tell you from experience.
As for H-pipe I would go with a VRS catted x-pipe.
Good Luck.
V
v8only
2,378
22
49
Oct 14, 2005
#13
  • Oct 14, 2005
  • #13
well, this has been beaten to death, but ALL 5.0 ford shorty headers are designed to work with all ford 5.0 heads
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 14, 2005
#14
  • Oct 14, 2005
  • #14
First time I've ever heard that. They gave me a nice increase in mid and upper range power. They were the first mod I ever did to my car.
I have a Borla aluminized steel (not stainless) catted X-pipe on mine. It was the same price as the BBK and the shop that does all the work that I can't or don't want to (www.bradscustomauto.com) recommended them highly. I've been very pleased with the results.
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Oct 14, 2005
#15
  • Oct 14, 2005
  • #15
wythors said:
First time I've ever heard that. They gave me a nice increase in mid and upper range power. They were the first mod I ever did to my car ......
When I bought my SSP (bone stock) the first thing I did was run full exhaust with 1-5/8" tube unequal shorties, a cat'd H and 3 chamber cat-back ..... it rev'd a little more freely up top and didn't choke out for an additional 500 rpms or so. (As is common knowledge amongst those that have played a little.)
Of course I lost a few ft/lbs below 2500 ... but negligible and worth the trade for me. I've heard of some guys losing a few ponies overall as well, but it's the complete combo that will make the difference.
With a stock build, I would consider buying a good aftermarket set with the stock size 1-1/2" primary tubes. You'll keep the backpressure, but flow a bit better than the factory units ... although your future will most likely hold better flowing parts, the trade now is probably worth it in the long run to just go with the FRPP shorties, which are a nice quality header for a street car .... buy once.
Adios
04sleeper
2,674
14
89
Dallas, TX
Oct 15, 2005
#16
  • Oct 15, 2005
  • #16
I dynoed my car with stock ported headers, then FRPP 1 5/8" shorties and LOST 4 HP and 6 ft lbs. peak (2 to 3 on both throughout the range). Then I tried some 1 1/2" equal length MAC shorties and lost 3 HP and 4 ft. lbs. So I ended up putting back on my "Ugly" stock ported headers and the power went right back up. This is with a VRS X-Pipe with no cats and Dynomax Super Turbo mufflers and 2 1/4" mandrel bent Dynomax Tails.
BTW. the Dynomax were worth 5 HP over my old rusted out 2 chamber Flowmasters.
xherdlr
159
Hendersonville,Nc
Oct 15, 2005
#17
  • Oct 15, 2005
  • #17
FRPP will bolt up.They will work fine with any motor upgrade you make...They will also work with the P head..My only suggestion is get the ceramic coating.Ive had mine for 3 years and they still look new. I orginally bought a set of BBK chrome and the quality was very poor.. I sent them back and bought the FRPP shorties.
Kelly
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 15, 2005
#18
  • Oct 15, 2005
  • #18
I would bet your problem was lack of back pressure, not the headers themselves. Replacing the x-pipe with a catted x probably would have given you more power with the headers.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
