FRPP SPRING HELP OR HURT BUMP-STEER
Compared to what?
In general, B's give a pretty decent front drop so chances are (depending upon what you have now), it will hurt.
It will hurt your bumpsteer. ANY drop (even 0.1" ;)) effects the bump steer. It's a matter of how much.
For drop 1"+, you SHOULD get a bumpsteer and CC plate. Get MM or Griggs! Also, with CC plates, you should have an STB because you're now putting a LOT of force on the POS strut towers.
Also, IMHO, B springs are VERY foolish unless you live in an area that has very good street. MOST people do not. But, some people do.
Here are some of my ramblings about springs/suspension mostly just thrown together.
http://veryuseful.com/InvisionBoard/index.php?showforum=2
There is a lot of information. Unfortuately, most of it is still very poorly organized.
How would CC plates put any extra stress on the strut towers???
I can definately see now coil overs would do so, but not CC plates.
In the stock setup, the POS strut towers are isolated from "short term" suspension forces because of the *soft* & *wide* rubber bushings between the strut and the POS strut tower. Still, under "longer term stresses" (like cornering) the POS strut towers will move.
With CC plates, you have a bearing between the top of the strut and the POS strut tower. So, you in fact put new massive forces on the strut towers. Most of the force is "mainly vertical", which the strut towers can handle with out "too much concern". But, it's the horizontal forces that the strut towers are weak at.
If you look at the strut setup, you'll see that on *any* bump, there will be horizontal forces transfered to the strut towers.
sure. there'll be SOME horizontal stress put on the towers, but its not like the struts are at a 45 degree angle here. Those bearnigs are really only going to transfer extra load in to the strut towers in cases such as speed bumps and pot holes. If your shocks aren't getting hammered by extreme road irregularities, I can't see how there is going to be a problem.
Nope! You're very wrong! :)
Those bearings mean that the top of the strut is basically "BOLTED/WELDED" to the strut tower!
Every single inch the car moves, the struts WILL put a LOT of HORIZONTAL stress on the strut towers. You need to learn about struts/ forces/ and the forces on each tire as a "big" vehicle goes over real life roads.
Even if the strut was at an ~70 degree angle, that would men that *approx* 20% of the force would be in the horizontal plane.
"Also, IMHO, B springs are VERY foolish unless you live in an area that has very good street. MOST people do not. But, some people do."
S&B, can you elaborate on this? I have a set of C springs in right now and those are harsh on our New England roads 7 ways to Sunday. I was thinking of installing Bs to improve ride quality resulting from the softer progressive springs. Why don't you recommend these?
"S&B, can you elaborate on this? I have a set of C springs in right now and those are harsh on our New England roads 7 ways to Sunday. I was thinking of installing Bs to improve ride quality resulting from the softer progressive springs. Why don't you recommend these?
First of all, stop lying to people. New England does NOT have roads! Stop the LIES! We have potholes connected with very small patches of asphalt! :D :D
:lol:
See:
http://veryuseful.com/InvisionBoard/index.php?showtopic=8
(*today*, it's the 2nd to last post)
Also, a lot depends on your struts! Also, your sway bar bushings, STB, sub frames, etc. If you're running "OEM or K&B" struts, you have a huge mismatch to your springs. Going to a Tok or Koni strut will improve things.
Also, with that amount of drop, you *need* CC plates and a bumpsteer kit. Well, you only need them if you want the car to handle properly. Many people lower their car because they THINK it will handle better, or for the Ricer look.
Hey, image driving a lowered '86 T-bird in MA/CT during a blizzard! Anything over 2" of snow on the ground, and I was plowing the street for free with my front air dam. Yup, my T-bird convinced me to get a FWD car for the winter. :)
In fact, with that amount of drop, you should have a spring rate of 700-800 lbs/in.
