FS/WTT: 91 Mustang LX 5.0 5 Speed w/50k Miles Ohio
chris91
Up for sale or trade. 91 Mustang LX 5.0 5 speed. Maroon exterior in great shape. Only flaw is the rear hatch has started to rust like typical Fox Body Mustangs do. Small bubbles, no rust ANYWHERE else. A $100 hatch and you have a perfect car. You could eat off the bottom of this car. Small paint fade on bumpers but not bad. Black/Gray Interior is in great shape. AC and Smog Pump have been disconnected but are still mounted.:rolleyes: Car has 50k original miles and I have the Autocheck(Ebay) to prove it. Car has sat outside a majority of its life though and the Rear Quarter window trim shows it. Not HORRIBLE, but they show their age. Car runs great and I would trust it to drive anywhere. I just get bored very easily and really want another 94+ Mustang GT/Cobra. Must be a 5 speed if you have a trade. I have many more pictures of it at every angle or if you have any questions feel free to ask. $7000 OBO or Trade.
Cobra Intake Manifold
70mm Throttle Body
Wolverine Cam (Similar specs to Ford E Cam)
ARP Hardware For Top End
Solid Motor Mounts
MSD Coil, 6AL, 2 Step, RPM Activated Switch(For the Autometer Mini Shift Light)
MSD Plug Wires
Adjustable Fuel Pressure Regulator
K&N Filter in Stock Airbox
Underdrive Pulleys
Pro-Form Electric Fan with Adjustable Thermoswitch
180 Degree Thermostat
UPR Radiator Cover
BBK Longtube Headers
BBK X Pipe
Flomaster Catback Exhaust
Southside Lower Control Arms
Full Length Welded in Subframe Connectors
Eibach Front and Rear Sway Bars
Full Autometer Gauge Cluster(Speedo, Tach, Fuel Level, Oil Press, Water Temp, Volts) Autometer Mini Shift Light
Aluminum Clutch Quadrant
MM Firewall Clutch Cable Adjuster
Pro 5.0 Shifter w/ FRPP Cobra Shift Knob or Can Swap it out for a Hurst Shifter w/ Plate and White Hurst Shift Ball
Centerforce Dual Friction Clutch
JVC Cd player
10" Bazooka Tube Mounted in hatch
17x9 03-04 Chrome Cobra Replicas with 245/45/17 Tires in Great Shape, Chrome bubbling on one wheel.
Only rust on the entire car.
Exhaust Video-(Pony's are long gone and it was cold outside, no the car doesn't smoke.)
91 Mustang LX - YouTube
