Fuel filler neck gromet replacement
Bolt on 5.0
302
Suffolk, NY
Guy just wanted to let you know that the filler neck gromet can be replaced without removing the fuel tank. I was very happy that I did not have to drop the fuel tank for a second time after I replaced my fuel pump. Here are the steps needed to take.
1. Remove 1 bolt on tank that holds filler neck support.
2. Remove 4 bolts under car for fuel compartment seal.
3. Remove three bolts around filler neck in fuel compartment, first remove fuel cap to access.
4. Remove 4 bolts around outer diameter of fuel compartment. 2 bolts for fuel door, and 2 on apposing side.
5. Push down on filler neck in compartment to break seal free.
6. Wiggle filler neck and twist and pull. With little effort you will be able to completely remove filler neck from fuel tank.
7. Replace grommet. Use Vassoline to lube up new grommet for easy installation.
8. Reassembled in reverse order
I had to, but it might be a little different on my 95. I tell ya what, doing it with a tank that's about 3/4 full is a messy, smelly job. I hadn't killed that many brain cells since I was a teenager. :D
damn man 3/4 tank that sucks. Yeh i beat the crap out of mine tring to burn off as much fuel as possible. I also did so nice turns figured Id make the fuel spill out of the tank haha. I went through over a quarter of a tank of gas in like 6 miles.
i got to replace the grommet on my car and i found out the hard way i smelt gas the other day and couldnt find it nowhere and then today i filled my car up came back outside and there it was leaking so i got to burn some gas and thats funny bolt on 5.0 my brother was telling me to do the same run the crap out of it and burn the gas down so i got some driving to do tomorrow
