  • 1994 - 1995 Specific Tech
Fuel Filter
  • Thread starter Thread starter 94-302-vert
  • Start date Start date Sep 16, 2008
94-302-vert
1,947
NE CT
Sep 16, 2008
  • Sep 16, 2008
What tool or tools do I need to change this?
Thanks!
Zero_chance
1,244
Maricopa, AZ
Sep 16, 2008
  • Sep 16, 2008
A pick to release the plastic clips on either side, a flat head screw driver or 8mm socket with ratchet to release the clamp that holds it in place. Its recommended to replace the plastic clips because they get brittle with age. Its also easier to insert the clips in the proper orientation on the fuel lines and then snap them back onto the new fuel filter once its tightened back into the holder.
94-302-vert
1,947
NE CT
Sep 16, 2008
  • Sep 16, 2008
Are the clips an autoparts store item or a dealer item?
Zero_chance
1,244
Maricopa, AZ
Sep 16, 2008
  • Sep 16, 2008
Either or. Dealer will likely be more expensive. Most parts stores should have them though.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Sep 16, 2008
  • Sep 16, 2008
I got clips with my new filter. Watch out for the o-rings in the fuel lines, they can fall out and you'll have a nice fuel leak.
desertcox05
379
south atlanta
Sep 16, 2008
  • Sep 16, 2008
i got the clips with my filter too
Zero_chance
1,244
Maricopa, AZ
Sep 16, 2008
  • Sep 16, 2008
Some do, some dont. I use predominantly Motorcraft parts and 90 percent of their filters dont come with new clips.
FlyBy763
439
Palm Bay, FL
Sep 16, 2008
  • Sep 16, 2008
Really? Thats why I DO buy Motorcraft ones, because they have all come with the clips. Odd...
Zero_chance
1,244
Maricopa, AZ
Sep 16, 2008
  • Sep 16, 2008
At the dealership, Ive only gotten a few over the last five years that have actually come with clips. Any time I need clips I have to get them from the parts room. Who knows, maybe the guy in parts takes them out of the boxes I know the few that we sell at Advance dont have clips in them. Kind of off topic, main point is that if the filter doesnt have new clips, its a good idea to grab some.
R
reldapimp
94
#10
  • Sep 19, 2008
  • #10
This is really easy to do.. All you need is a Flat Head and a towel to protect you from all the gas that WILL spill all over the god damm place...
1) Buy from Motorcraft(it has the clips you need)
2) Unplug the fuel connector in your trunk... (driver side) Start engine and let it run until it dies
3) Get rear end on jackstands
4) Go underneath the car from the BACK
5) Near the back of the rear tire passenger side.. RIGHT infront of the fuel tank is the filter.
6) Unscrew the metal clamp.
7) Pry the Plastic clips off the filter
8) Grab your towel and pull the fuel lines off the filter(gas will get all over the place if you dont...
9) Remove old filter.. Put in new filter in SAME direction... Put the metal clamp back on...
10) Reconnect fuel lines AND the safety clips and make sure they dont come off.
11) Wipe EVERYTHING in the area down with a towel and some water.
12) Plug in the connector in the trunk.
13) Start car/Check for leaks... And remove jackstands..
Your all done... I did this acouple of days ago and its easier than installing the MAC intake...
Slo 5.Ohh
14
#11
  • Sep 21, 2008
  • #11
every filter i have bought has come with the clips
HISSIN50
34
129
Sep 21, 2008
#12
  • Sep 21, 2008
  • #12
If no one mentioned it, de-pressurize the fuel system before starting. This can be done with a bypass fuel-pressure gauge at the Schrader valve.
R
reldapimp
94
#13
  • Sep 22, 2008
  • #13
Or just unplug the connector in the trunk.... And let the car run until it shuts off
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
A
87 GT - Low Fuel Pressure Problem
  • Asbury
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Time sert kit!!!!
  • Bmanmcbride
  • Jan 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 14, 2026
LILCBRA
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
