well to start off, i have 1969 mustang and i want to drop a fuel injected small block in it. i was thinking of going with a CHP 427 or 408 stroker or a DSS 408 stroker. and toping it off with some trickflow heads and intake with an agressive cam, possibly one of the kits that are offered for the 351w base. i want to go with a mass air system for sure. i am not sure if this will be an N/A or supercharged engine (depends on budget). my question to everyone is about the ECU. what would everone recomend as far as a factory fox computer or possibley an aftermarket if availible. i was recomended to use the A9L or A9P (i will be using a tremec 600 manual trans) i looked at some ECU's online at stangparts.com and they have the option to choose a calibration code. either an E7SF-CA or the E7SF-EA... i dont know what the difference between the two are.
i just need your recomendations as to what ECU to use and/or your input on the engine combination.
thanks
thanks
