Fuel injection VS carb. 500hp engine.
Fuel injection or carb?
  • Fuel injection
    Votes: 10 47.6%
  • Carb
    Votes: 11 52.4%
  • Total voters
    21
  • Poll closed .
As a lot of you know I have a 1968 coupe that I intend on building a street rod out of. I am intending to hit in the 500hp range, I would like to use Ford Racing's 427 stroker (351). I know that fuel injection costs more that carbs, is it worth it? Does it give better throttle response? Does it work better with NOS? Opinions please!
the only advantage that EFI has over a carb is the tighter control over the fuel mixture. both can have razor sharp throttle response when tuned properly. the EFI system will usually allow for better fuel economy, and smoother performance across the rpm range. there will be no change in power with either system.
The key to "EFI like" throttle response with a carbed setup is to not over carb the motor and run a good electronic ignition system. And run a wide LSA cam, same as EFI. You can have your cake (carb) and eat it too. The only place EFI shines over a carb is in big altitude changes. Something, you're not going to see in east texas.
I guess I'm the only one who reccomends you go to EFI.
I used a carb for 8+ years before going to EFI. I will never go back to a carb.
BUT! To be honest, carb vs EFI is a very personal choice and depends on knowledge, skill, goals, and the vehicle/engine. I'd have a lot harder of a time justifying EFI on a drag-only car for example. But even then... if you are hardcore drag racer EFI is the way to go. The stand alone ECU's allow you to do things like launch control, N2O control, wastegate (turbo) control, allow you to quickly change tunes for different fuels, etc.
Simply deciding if you are going to use EFI or not isn't really enough. I think you first need to consider the different types of EFI available and see if you are willing to do the work involved to get themup and running. Once you have figured that out then you can sort out if you want to do that over a carb setup.
Carb setups are easier to get started. Less wiring, less bolts and they do (in my opinion) look better.
EFI setups basically require computer controlled timing which adds to the complexity. You can have a computer controlled ignition system without EFI but having EFI without the computer means mechanical fuel injection... ask Porsche why they don't use that setup anymore....
EFI will be easier to tune in the long run, especially if you are going to run nitrous.
A friend of mine has a speed shop, builds all sorts of exotic street machines. He figures a daily driver is a toss up, but when going for extreme power the carbureted engine has an edge. He should know. He has a chassis dyno built into the floor of his shop, so he can maximize power with the hood up, and all diagnostic equipment connected.
EFI would have been nice on my supercharged setup, but really, the cost difference from carb to EFI is ridiculous. About 1000 for carb, about 3000 for EFI. A no brainer at this point. Maybe some day ill switch, but i hate wirering, so i doubt it.
Id also like to see how many people that vote for EFI actually have it, or just think its cool on a old car.
I have efi on my car and can say that you need to be realistic about the intended use of the car before making the decision.
Power and torque will be about the same at the end of the day.
EFI will yield better fuel economy in real world day to day driving. But if all you do is take the car out on weekends to cruise or pound on it, what do you care about mileage?
EFI will start everytime at any temperature with the twist of the key, no stomping the gas pedal, no fooling with the manual choke. But if you only drive in nice weather, who cares?
EFI has unlimited tuning capabilities, but the learning curve is very steep.
Production based EFI systems weigh considerably more than carb setups so if weigth is a big deal for you, recoginize that.
And by the way, I get many, many more people that think I've ruined the car versus those that think the efi is cool.
My car puts maybe 275 HP to the wheels and I drive it probably 3 days a week to work and open track it occasionally. It drives just like a modern car with 20 to 25 mpg if I don't beat on it too bad.
But if I had to do it again, id probably have to go with a carb. But that's me.
Good luck...
I love EFI and I've even done an EFI conversion on a carbed car, but IMO unless you drive the car all the time and many short trips it's not worth it. I don't really like carbs but they are a lot cheaper.
Of course unless you tune on a dyno or have wideband O2 sensors on the car you will never get a carb tuned as well as EFI will naturally tune itself. That also means you will never make as much power with a carb unless you do the extra tuning work. Also, a carb will make great power right after it's tuned but it won't self adjust like EFI. Just realize a carb is cheap and easy to install but not as good as EFI in power, fuel economy or driveability in the real world. I would go with a carb in a summer only car, but not because I think it works nearly as well - just because it's cheaper.
I got mine used for 1300.00 used for 3 months and the guy decided to go stacks,
http://www.autopartsdealer.com/professional_products_powerjection_iii_kits_70026-p240053-p.html
or you can go port injection
Professional Products Powerjection II Kits 72003
These new self tuning "TBI's" will give port injection a run for the money, unlike the old type TBI these run 45-60 psi fuel pressure giving great atomization and wide band 02 sensor, its a proven fact that the further away the injector from the port will give more power except for direct injection of course.
I have seen a few dyno runs comparing the powerjection tbi and powerjection port inj and they were almost exactly the same, also the EZ-efi TBI versus the fast port injection and the same results less than 10% difference in hp gain and the ez-efi tunes itself.
You can spend hours of tuning on a carb and match the hp of efi but the throttle reponse and most of the time TQ will be much better with efi as well as fuel economy and efi compesates for hot/cold weather, altitude, humidity and it will make a lumpy cam idle much smoother, I have personally experienced this with efi in the past.
You can spend hours of tuning on a carb and match the hp of efi but the throttle reponse and most of the time TQ will be much better with efi as well as fuel economy and efi compesates for hot/cold weather, altitude, humidity and it will make a lumpy cam idle much smoother.
Aside from drastic altitude changes (we ain't got that problem here) I have none of those problems using a carb(s)
Regardless of how well you tune a carb, real world fuel efficiency will never match any modern efi system.
I will grant you that at cruise you will be able to match efficiency with a very well tuned carb but at every other point, which is where most driving occurs, efi will win.
In closed loop my 20 year old EEC system is always trying to hit a stoich burn at any throttle position less than 50%, always.
A carb simply cannot match that.
Carb N/A
Fuel Injection turbo/supercharger
I personally hate the look of fuel injection setups on old cars. There are a few that mimic a carb and look stock, which i a nice way to go. 5.0L intakes just look out of place in a classic IMO, kinda like the modern 5.0 wheels with the goofy wheel offsets.
;) So tell me what the exact power output difference is between the two at any given RPM ? :D
