  • SN95 4.6L Mustang Tech
Fuel Injector Question
  • Thread starter Thread starter fiveO92
  • Start date Start date Jan 11, 2006
F
fiveO92
  • Jan 11, 2006
I did the PI swap on my 98 gt and I have other bolt-ons like cai, plenum, tb etc. I was just wondering if getting new injectors would produce anymore performance with this set up and if so what lb. injector would be the best? Thanks for the information in advance
F
fiveO92
  • Jan 11, 2006
I'm also in the process of getting longtubes...didn't know if that made a difference.
98blackmagic
386
wouldnt you like to know
Jan 11, 2006
  • Jan 11, 2006
for what you have I would get a set of 24's, no bigger than that. with the pi swap and full exhaust and every bolt-on you would have over 300 at the flywheel and the larger injectors would be needed.
F
fiveO92
  • Jan 11, 2006
Thanks My brother keeps telling me that I should get a nitrous kit but I'm not sure if I want to do that and I'm not sure what shot to run or anything. Ever since I saw my buddy's 98 cobra have trouble starting and then seemed like it didn't want to run after he raced an evo 8 I've been kind of worried about doing that to my car.
98blackmagic
386
Jan 11, 2006
  • Jan 11, 2006
some people like it others dont, its all up to the persons taste. I have never had it and dont want it, my car has a new motor going in now and will be toped off with a blower this spring. I know a lot of guys here on :SNSign: do run it and have NO problems, I think its all in the installation and weather or not you abuse your car spraying to much to often.
BLKsteeda
236
Anywhere
Jan 11, 2006
  • Jan 11, 2006
I have every bolt on plus Stage 1 cams and MPH Ported Heads and when steeda did the install they said that my 19lbs were flowing plenty for those modifications and they did not have to upgrade
98blackmagic
386
Jan 11, 2006
  • Jan 11, 2006
Everybody is going to have their own opinions on what size injectors to run, but for this application with the PI swap and full bolt-ons most everyone would say to run 24's. I think the 19's limit is around 325hp I think, and that would be pushing it, I would rather be sure to have enough fuel than to not have enough.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Jan 11, 2006
  • Jan 11, 2006
your stock injectors will be fine for your setup.
01Steeda
732
Baton Rouge, LA
Jan 11, 2006
  • Jan 11, 2006
I just had Patriot stage 2 heads and 233/247 113 LSA cams installed on my steeda. We had to go with 30# injectors. the 24's were being over run. I also have Steeda pulleys and exhaust. I am definatley not a guru, just my experience.
squares98
852
Orange,ca
Jan 11, 2006
#10
  • Jan 11, 2006
  • #10
to the Original poster, 19lb. injectors are still up to your task. No need to buy new injectors till you need them.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 11, 2006
#11
  • Jan 11, 2006
  • #11
19's will take you quite a ways in N/A trim.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
K
2013 Mustang GT Fuel Injector Question
  • KHills5058
  • Nov 4, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Nov 6, 2025
KHills5058
K
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
